Clearance Of Intake/exhaust Valves
May 19, 2014
3
hunter 29.5 san carlos Sonora
HELLO MY BOAT IS A HUNTER 29.5 WITH A YANMAR 2GM20F engine
could you pleae inform the intake7Exhaust valve clearance ?
Regards
Nov 6, 2006
10,246
Clearance for both intake and exhaust is 0.2mm or about .008", cold. If ya have no history on the engine, it might be prudent to torque the head bolts (29-32 ft-lb) while you are in there. The manual in the downloads section that Ralph referenced has the tightening sequence.
Jan 30, 2012
1,154
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
From memory the clearances mentioned are correct.
I do not understand why you would re-torque head bolts. However - as I recall - there are 8 head bolts. Two are 8mm bolts the other six are 12mm. The torque values are different for each size. Anyway check the manual for what Yanmar says about re-torque. Also check the manual for torque values. 32 ft-lb is way too low for 12mm head bolts but it might be right for rocker arm supports.
Charles
303
Hunter 28.5 Jordan, ON
If the engine uses torque to yield head bolts then I'd not tighten them. You generally replace head bolts if pulling a head for any work.
Nov 6, 2006
10,246
My mistake on the torque number.. the correct torque is 72 ft-lb for the big nuts and 18 for the two small ones on the exhaust side. The other number is the torque for installing the head stud into the block.. Yanmar does recommend re-torquing the head after 50 hours and then every 1000 hours after that.
