Cleaning the Rub Rail
Tom
The toughest thing I have found to clean on my H240 (and even on prior boats) is the Rub Rail. It seems impossible to clean. Any recommendations??
Robert Polk
Mary Kate Spray Away
This product is fabtastic - Also good for inflatables. Available at West Marine
C
CORKY TROTTER
rub rail
I use Brillo on my rub rail and works fine. ct
Mark
Ajax
Almost every time we pull into jetties down here our rub rail gets covered in "BLACK" gunk. Our city council in this town is about 20-30 years behind any other coastal town when it comes to providing decent boating facilities. Our jetties are still clad in old car tyres. We use a product called AJAX. It is a very fine abrasive powder used in kitchens, bathrooms and it removes all stains with ease using a damp cloth to apply. Only thing is that you need to make sure you do not come into contact with the Gelcoat. Regards
MIke D
Soft Scrub
I know that soft scrub with bleach works great. I am not sure how good it is for the rubrail material though. Use it with a scrubby type 3m pad or other mild abrasive.
Joe
Simple Green
We’ve tried acetone, patio furniture cleaner and a number of other chemicals. This past season we used Simple Green and were pleases with the results. When you apply it you have to let it sit awhile but not to the point where it starts to dry. Then a stiff brush or a scotch bright scouring pad will work. Then fresh water rinse. It does take off wax so where ever it drips or sprays onto is going to need to be re-waxed. We also applied wax to the rail and it looked great the whole (6 month) season.
Sep 25, 1999
600
Hunter 23.5 Indian Lake
rub rail
meguiars has a product for rubber and vinyl etc, it worked good for me, good LUck Mike Bacome
C
Crazy Dave Condon
Tough stains
Too often folks have not cleaned the rub rail. There are all types of solutions; however if everything else fails, then the last resort is the following. Use acetone as the last resort. IF that don't get it, then you can sand the sucker with maybe 400 grit wet and dry. If using acetone on the HCT boats or anything under the 212, be extremely careful not to get acetone on your boat or it will melt. Crazy Dave Condon
Joe R., SV Skooky 3 - Cat 30
Did anyone try Island Girl pink?
And if so, what were the results?
