3M Perfection
Gary,When I bought my 1978 Hunter Cherubini 33, "Tainui", the hull was very oxidized and looked like it never had a wax job. At first I used 800 grit and moved up to 1000 grit wet sand paper. afterwards, I washed the hull, waited for it to dry and then used a cheap harbor freight variable speed 3,000 rpm polisher. Be sure you buy the professional 3M wool polisher pad (2 sided). I highly recommend you also use an arbor extension on your polisher. This gives you the extra room for the polisher pad to bend as you muscle your machine into the hull. I used 3M "Perfection" compound polish/cleaner and I am very satisfied with the results I obtained on a 27 year old hull. Top it off with a good teflon RV/hull wax with UV protection and you will be in business. I hand rubbed the was on the hull and used the other side of the buffing pad to buff it out with. When using any compound using a polished at 3,000 rpm be sure no other boats or cars are near by, the material can sling a long way.Good luck and happy sailing.
