cleaning sunbrella
Jun 26, 2004
150
Hunter 41DS Reed Point Marina
On a fairly new inclosure and dodger, I have a lot of green showing up on a light grey colour sunbrella. any suggestions on cleaning. I'm in Pacific north-west lots of rain this year.
I followed those cleaning tips last year, they work. I found mixing both the Woolite AND a little bleach together on ONE mix did it best. I have a light tan dodger, much like your light gray.
Nov 13, 2013
723
Catalina 34 Tacoma
I just took a power washer to my sunbrella boat cover. Not the factory approved method but worked quite well.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
I filled a large plastic garbage can with water and dumped some bleach in it. Stuffed my main cover in and used a 2x2 to agitate periodically. Left it in approx 24 hrs. Spread it out on the driveway and gave the problem areas a good stiff brushing and put back in the can For awhile. After several rinses, spread it out to dry. Worked quite well..
Mar 26, 2011
3,841
Corsair F-24 MK I Deale, MD
The green is best prevented by regular water repellent treatment. That helps it dry more quickly. Treatment with a quaternary amine silicone compound, such as Goldshield, is also very helpful. Even benzalkonium chloride helps for a few months.
[I had a friend in Seattle test these products for me in his climate]
Aug 28, 2006
578
Bavaria 35E seattle
I used Woolite mixed with white vinegar on my light grey sunbrella. It works well for the green stuff but takes some elbow grease with a stiff brush, too. I was reluctant to use bleach.
Jan 24, 2017
671
Hunter 34 Toms River Nj
try hydrogen peroxide and white vinegar 50/50 mix this mix is used on spa covers to remove algee and mold and not as hash as bleach
