I recently cleaned...
... the bronze shaft and prop on my H28.5. It had a number of years of bottom paint on it. I began with a electric drill loaded with a paint scraper wheel, which took most of the old paint off. Then coarse sand paper and worked my way down to a fine grit. Prop and shaft now look like new. The real question is how to protect them from fouling when I launch next month. I was surprised to learn that Don Casey suggest doing nothing or coating the prop and shaft with wax. IMHO, that would last about a few days. I am also not inclined to jump into the mostly polluted Chesapeake to clean the prop and shaft every few weeks. Casey also states that a copper based paint and bronze hardware are incompatible, although that was on my prop and shaft and did no noticeable damange of any sort. In any event, I plan to prime the shaft and prop with a lead-based spray primer and paint them again with bottom paint, probably modified epoxy since that seems to last longer. The old bottom paint did a very good job of keeping the shaft and prop free of barnacles and other growth.
