Cleaning old fuel residue
Ross
Jun 15, 2004
14,693
I have been working a a house that is heated with fuel oil and the tank fill fittings leak. The result is a 275 galllon steel tank coated on the outside with dust and fuel oil of many years neglect. This morning I tried two methods for cleaning. The first involved a hand towel and full strength Spic and Span liquid cleaner. I spread the towel and poured on the cleaner to wet the towel and left it to soak for an hour or two. It was very effective, taking the crud off right down to the primer paint. The second method used Easy-Off oven cleaner "No Fumes" and no sodium hydroxide. That also worked very well around the pipe fittings.
I have no idea what the EPA response would be but in a poorly ventilated basement it was not unpleasant. The wash water is nasty looking I wouldn't pump it over board.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I'll have to remember that Spic and Span recipe, Ive had good luck with Simple Green on fuel cleanup either gas or diesel
Ross
Jun 15, 2004
14,693
The dribbles that ran down the sides left clean streaks and dirty puddles on the floor. AND the funky washed out of the towels rather well and easily.
RichH
Feb 14, 2005
4,773
One of the best fuel oil crud removers Ive ever found was a recommendation by the application engineers at WEST SYSTEM EPOXY, Gougeon Brothers ..... "Pour and Restore" garage floor cleaner. It liquifies the crud and 'soaks it up' in a gel like form which is easier to remove than 'blobs'. Its a 'caustic' so you need to wear protection.
