Cleaning Interior Cushions
Elie
Dec 15, 2015
26
Hunter 29.5 Marina Del Rey
Hi Guys,
Anyone have any suggestions on how to clean the interior cushion covers? Do I need to dry-clean them? washing machine? see attached pics of my cushions.
Thanks!
Elie
2,362
the one time I got the cushion covers cleaned, I sent it to dry cleaners. That was several years ago. Now I'm thinking of washing in my home machine.
Jan 24, 2009
450
1981 Cherubini Hunter 27 Shipwright Harbor Marina, MD
I recently ran my circa-1981 brown tweed ones through the washing machine on a hot cycle with laundry soap and a splash of Lestoil to help with the diesel smell. The threadbare spots didn't do well, but the rest is OK and it really killed the smell. If there is a tag somewhere on it or you can verify they are acrylic, they will not shrink, nor should they bleed. Search the internet, there was a chart from Sunbrella about what to use on various stains. Washing them will take out any stain resistant or waterproofing treatments (Scotchguard or 303) and those will have to be re-applied (which is possibly more important for exterior covers).
Smells also collect in the cushions and I washed mine by hand in the bathtub with a similar hot water solution to try and kill the smell. That was moderately successful, not perfect, but bearable to my sensitive nose. Wet cushions are very heavy and took days sitting outside on the back deck in the sun to dry. If needed, there is a process for getting the cushions back in the covers using plastic cushion silk and a vacuum cleaner to compress the cushions so you can get them back in. I think it was on the Sailrite web site. They sell the silk also.
Ted
Jan 26, 2005
1,270
Dkeagle touched on a very important point. You must know what type of material you have so you will know how to go about cleaning your cushions. Some fabrics can only be cleaned with water based cleaning solutions while others by dry cleaning or similar processes only. If you're not sure, test your product in an inconspicuous spot before doing the entire project.
Likes: SailormanDan
Jun 6, 2006
6,990
Getting the foam dry is pretty simple. put it in the washer and put it on spin. May have to balance the load with two similar cushons.
Likes: SailormanDan
Jan 24, 2009
450
Probably for durability & stain resistance they are acrylic, but a good idea to test them, especially since to get oil (petroleum products) out and warm/hot water works better, but is hard on cotton. Your mileage may vary, of course.
Les
May 8, 2004
375
Hunter 27 Bellingham, WA
When I needed my cushions cleaned on my Hunter 380 I called the local chartering companies and found out who they use. It appeared a local cleaning company did offices and most of the chartering boats. They came down to the boat, picked up all the cushions, cleaned them and returned them to the boat and installed them. And the cost was quite reasonable. I'd use them again.
Likes: SailormanDan
Oct 29, 2005
2,362
there are some back rest cushion that is not shape sponge but fluffy(?) stuff. I suppose just put this in a bag when cover is washed.?
Jan 24, 2009
450
It sounds like some kind of polyfill - might be in its own inner pillow case and you won't have to mess with it. But you're right, you won't want to wash that.
Dan_Y
Oct 13, 2008
517
Hunter 36 Hampton
On our '91 h30 we washed the covers and foam cushions in a tub with laundry soap and oxyclean. Did the foam cushion first and let dry, then washed covers and put them back over the cushions before dry to combat any shrinkage per the dealer's recommendation. worked well on covers but we couldn't completely remove 20+ years of boat smell from the foam.
Likes: SailormanDan
Sep 3, 2012
195
Hunter 285 Grand Rivers Ky
I was always told for health and safety reasons you should NEVER dry clean bedding, matrasses, pillows, or cusions that are used in a closed cabin boat. But instead, the same place that does dry-cleaning can usually also do big machine laundry. This would be OK. And I suspect big machine laundry is easier on the fabric.
Washed ours in big laundry, cool water, they seem fine.
Hi Guys,
Thanks!
Elie
Likes: Nick
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I once cleaned our sails in a hot tub. It worked out okay but it wasn't easy. I did let them soak for a long time. I'm just wondering if that would work for cushions.
Ken
Jan 24, 2009
450
No it wasn't easy for me either because you have to squeeze them good to get the soapy water out and then rinse them and squeeze them several times to get all the water out before carrying them out of the house. I think I put on my foul weather boots and stood in the bathtub and walked the water out as best I could.
I would have like to have done them in the washer, but we felt that would be too hard on the old machine, Maybe I need to look into going to a laundromat if I do anymore. The bestsolution is to replace the cushions, but I save hundreds of dollars if I can get the smell down and bearable.
Nick
Dec 8, 2015
33
x 1 x
We cleaned and deodorized our large foam cushions in a large kiddie pool (smaller cushions in the bathtub) with white vinegar/Clorox mix first for two days, rinsed, and then a soapy soak/rinse and rolled the foam squeezing the excess water and allowed to dry in the sun... in one/two days they were dry but this was over the summer months... now they are covered in Ultraleather with Downy pads in the bottoms to breathe and they are as fresh as the day we cleaned them... we'll repeat this in several years again. Boat smells fresh and no odors to speak of... we use Hawaiian scents throughout... Admiral loves being on the boat now more than I... :)
Forgot to mention... do not reuse the polyfill... throw away and get new polyfill and replace... you'll be glad you did... ours had 1/4" fill... we replaced with 1/2" polyfill and it has sure made a difference in the softness of the cushions.
Likes: SailormanDan
Oct 2, 2008
3,810
Pearson/ 530 Strafford, NH
We used some rug shampoo with a soft bristle brush, don't remember the name but comes in a red spray bottle.
All U Get
Any ideas on how to remove recalcitrant zippers?
And what do you do about the "buttons?"
