Is there a recommended procedure for conducting a thorough cleaning of freshwater holding tanks? I have (2) freshwater tanks, 1 in the v-berth and another on the under the starboard settee. The boat was in storage for 6 years, it was winterized but developed quite a bit of mold, mildew and scum in the tanks & lines (I don't think they were in great shape prior to storage already).
I'm going through and replacing all of the freshwater hoses but I don't think a chlorine soak of the tanks is going to be sufficient to get them clean. I don't need to get them to drinking water quality but I'd like to be good enough to use them for washing, cooking, etc.
For drinking water I've removed the hot water heater (was already inop.) located in the port lazarette and will be using that space to install a 5 gallon water tank (think water cooler tanks) connected to a small 12v diaphragm pump with a faucet/switch at the sink. This will be used solely for drinking water and can be swapped out easily once empty.
