Cleaning Carpet Headliner
4
Oday 272 St Pete
I have an '86 Oday 272 with a carpet type headliner. The headliner has some significant stains. Most appear to be water stains from past leaks (not leaking now). Any suggestions for cleaning the stains? I do have a Bissel steam cleaner with a hand attachment. What cleaner should I use that won't cause the headliner to detach from the boat? And is it safe to use the steam cleaner? Thanks in advance for any suggestions.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
I had good success with clorox cleanup
Some of my carpeting was stained and mildewed. I used a bissel steam cleaner with water instead of detergent, spraying the stains with clorox cleanup and rinsing with the water. Didn't get the stains out 100% but it made a big difference. The bleach in the cleaner did not affect the color of the carpet. Your results may vary, you would want to try an inconspicuous spot first... Manny
