Boat Cleaning
Tim,The following is an article written by the late/great Gary "Doc" Hansen, for the Trailer Sailor Bulletin Board. His method will result in an execllent finish without having to get out the electric buffer.Ben by Gary “Doc” Hansen A lot of people have been concerned here lately with putting some of the shine back on the ole boat after it’s long winters rest. All you have to do is go to the boat store, or the car store, and you will see the multitude of products available to choose from. They are almost bewildering to the senses with so many different crèmes, pastes, and liquids all to accomplish the same thing… A pretty boat. For this end, I am only going to give you MY expression of how to “rub on… rub off”. My method has been given the test of time, over the past 20+ years. I’m sure that it’s not the best, but it might just be the easiest. It begins with the first bath of the season… I just gave our boat one, and the mud just ran off the hull… How do they get so dirty just sitting still? The way I wash is probably more aggressive than that of most. Most skippers that have labored over polishes or coats of wax will cringe at the notion, but I use Soft Scrub with Bleach, and a “green pad/sponge” combo. I do this for the reason that the surface must be completely clean and FREE of other coatings. I am working on the FIBERGLASS itself and not putting on an overcoat. I use a product called “Marine Penetrol” and it is designed to “penetrate” the glass and restore the natural shine. This is NOT a mirror finish. It is more of a shiny clean look, but to me… that is the way I like the boat to appear. Living in the southwest, the sun and UV is our biggest problem on any exposed surface. Oxidation is the ruin of the gel coat shine, and a wipe of the hand over the deck will produce a chalky substance in just a few months. The use of Marine Penetrol in this environment has given me the ability to recondition the surface each year. I carry the can with me at all times and just give it a wipe down when ever I have a few minutes. The product goes on right from the can, using an old Tee shirt for a rag. Extra product that isn’t absorbed in a few minutes is wiped away. (My only “caution” to you is not to set the can down if any product has ran down the side of the can… it can leave a “ring” where the lip of the can sits.) I like the way it looks on the “composite” cleats, and my painted non-skid areas. It even seems to improve the look of stainless… but its primary accomplishment is keeping my glass looking white and clean. If that is what you are looking to see, here is the method I have been using for years: Wash the entire boat with a mild soapy water and rinse well. Scrub down the deck and cockpit areas with the soft scrub with bleach, and the green pad. You want the surface to be as white and clean as you can achieve, then rinse well. Allow the boat to dry, and get a quart can of Marine Penetrol and read the directions on the can. You will notice that the first thing the can recommends is restoring the fiberglass. You simply wipe the product on… and wipe off any excess. Man, that’s it… stand back and see what you’ve done! Now, wasn’t that easy? Take a seat on top of the ice chest and admire your work with a nice cold drink… The job LOOKS LIKE it took all day, so you’ve got some spare time. Enjoy
