Cleaning below decks
H
Hayden
I need advice on how best to clean the material that coats the inside of my Hunter 235. It appears to be sound proofing insulation made of some poly material that is supposed to be grey. It also seems to attract mildew over the winter and I haven't found anything that will return it to its former glory. It has those small grey/black spots of mildew that won't seem to come off with soap and water. A brush only messes up the texture of the material and I am at a loss. I'm sure others who have the Huunter 235 have found a way to clean this "stuff" HELP !!!!!!!!!!!!!! Hayden
Steve O.
bleach and H2O
I used bleach/water mix and found the color to be fast.
Jun 3, 2004
232
The Works...
Shower and tub cleaner. Lysol tub and tile cleaner works as well. Working inside your cabin might require plenty of ventilation. You should probably wear some gogles as well.
Feb 15, 2004
735
Hunter 37.5 Balt/Annapolis/New Bern
West Mildew Remover worked for me
really well. I used a mini carpet machines (Little Green) and tons of that stuff. Spray it, let it sit then wash with the cleaner. Then do it again. Came out pretty well. Wear a breath mask or something, the fumes will get you.
