Richard, I noticed...
in Fred's site pics that he had used what appears to be a Beckson. As my surveyor and others have addressed it, it's not an issue of pressurization in the tank that's the concern, but one of the nature of the materials themselves.
The Beckson (and like) generally use a small diameter O-ring as a lid gasket to seal between the lid and frame. The frame is then sealed to the tank with whatever one applies that will stick to the poly. The frame is probably just self-tap screwed to the tank (unless the installer is really dilligent about bolting it down with thru-bolts). The holes are tapered, which over-torqueing could break out (most likely when using bolts not screws). Lastly, the lid is torqued closed by hand tension, not tools.
The SeaBuilt unit is at least quarter inch thick stainless with 3/8" bolts and thick use-appropriate gasket material as seals on either side of the tank material, clamped down with significant pressure by the nuts and washers on top of the lid piece. Overkill to some perhaps, but designed to work on a tank's vertical walls as well as its top. Now that's piece of mind to me where fuel is concerned!
I'm sure the less expensive solution has worked for others, but safety has always been worth the price to me.
