Cleaning a fiberglass hull
K
Keith K.
I'll be putting my Cat22 in the water soon, but I'd like to make the hull shinier and cleaner. What product should I use, and how should I apply it? It's not filthy but it is a bit dull. Any help would be great. Keith K. S/V Vesta
Mac
Jun 7, 2006
436
MacGregor 25 KEUKA lake NY
3M Products
I have had two boats, one a 1978 and most recently a Catalina 25-1989. On both I made them look new and shiny. Wash your hull, I use tide laundry soap. Use 3M Heavy Polishing Compound. Put on with a buffer (wool pad) working a two foot sq area at a time, keep the pad clean by spurring it up with the reverse end of a pair of pliars. You can be aggressive. Wax it with 3m Ultra Performance Wax (paste-carnuba). It goes on by hand and I polished it off with a clean wool pad, you have to keep the speed down on the buffer or it will get hot and gum up. I put four coats on the boot stripe and three on the hull and it looks great, a bright deep shine. If the gel coat has darkend/oxidized due to sun you can sand with wet/dry sand paper 600 grit, then go with the rubbing compound and wax. Test the polishing compound first, the transom is a good place to start and learn. Hope this helps
Bob Camarena
Island Girl
I've had good experience with Island Girl products. Check out the Gel Coat and Plastics forum on this site. Island Girl takes a different approach than other companies plus, you can deal directly with the company's owner, Jim Willis if you need help/advice.
