Cleaning Diesel Fuel Tank
We had algea in our fuel system and per other peoples recommendations this is what we did.Pump out all the old fuel (we used a hand held bilge pump with lots of old towels around)We pumped ours into a rubermaid trash canVia the access opening we stuck our hands in as far as possible and cleaned the tank out, areas that you can't reach you can use a toilet bowel brush or something like it. Scrub, look with a head lamp, scrub, look with the head lamp.Next, we added some Carosine, I think just 1 gallon. We let it sit for a day splashing it around and soaking the sides 3 or 4 times during that day and night.Next, pump out the Carosine. Tons of paper towel, wipe the tank completely clean. Use the brush if you have too to reach tough spots. Look through the hole, clean, look through the hole, clean. Remove every last piece of dirt and grime.Finally we filled the tank with new diesel with a shock treatment of antialgea/fungal.Important, after we emptied the fuel from the tank we blew through the fuel line from the engine to blow any contaminated fuel/algea into the fuel tank.Lastly, after the tank was crystal clean with new fuel we bleed the fuel line and changed out the fuel filter. Hope this helps. We have been trouble free for a year. Whille you are in the tank, with the access hatch open, check your fuel guage.
