amperage limits
With all due respect to what Mike and Randy have said, a sensitive breaker is a possibility. If you look at the nameplates of the appliances in question, you will see what each is rated for in amps. Add up the amperage ratings for the whatever combo is tripping the breaker. Be sure to include ALL appliances that are drawing power. If the breaker is rated for 15 amps and the appliance amperage total is close to that, Mike and Jerry are probably correct. If the amperage total is significantly below the breaker rating, I would consider replacing it WITH A NEW BREAKER HAVING THE SAME RATING. The important thing is that under no circumstances should you exceed the current carrying capacity of the wiring system on the boat. If the power lines supplying the AC outlets on the boat are 14 gauge wire, 15 amps is the maximum capacity of the system. A system made of 12 gauge wire is good for 20 amps. Check the wire size on the power line connecting the boat to the dock as well. The same limits apply to it.
