G
Greg W
I wish to power a DC TV with a cigarette lighter plug which came with the TV. My plan is to strip off the plug and wire it directly to a fuse block. Is the wire which goes down the center of the plug to the tip the positive wire and the wire which goes to the side prong the ground or negative. I believe this is correct, but wanted to check with all of the master minds on this board first. Is there any problem with wiring directly to the fuse block?
Greg W.
"SlipAway"
Greg W.
"SlipAway"
