Chrysler Sailor Outboard oil mix ratio
3
2 C-22 Neenah
I have a early 80's Chrysler Sailor 250 outboard, it runs with what little fuel came in the tank. The old owner was less than informative, (just add some to the gas). Does anyone know the oil mix ratio recomendations? I was planning on 50.1 mix.
Thanks
Dec 9, 2006
694
Oday 22 Hickory, NC
I do know the Johnson/Evinrude came out with a motor in the 80's and said to run it at 100/1. After a bunch blew up they changed it to 50/1.
iboats.com has all kinds of forums on motors, check them out. You will get lots of answers there.
Jack
G
guest
Had one of those - use 50 to 1 mix
Thanks
Good old dependable engine if properly maintained.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Had a Chrysler 70HP outboard, 3 cyl with 3 carbs 2 stroke would burn 6 gallons an hour. 50:1 is the right mix.
Oct 12, 2008
42
chrysler 26 my house lower Florida Keys
Six gallons an hour? on a 70hp? WOW no wonder I gave up powerboats
well, we did save a nice skiff for calm days
