Chryler outboard
Ralph
My boat is equipped with a 1984 Model 71H2C 7.5 HP Chrysler Outboard Motor. Snapped off the fitting in the engine where the fuel line is plugged in. Nobody locally has one. Would really appreciate knowing where I can buy Chrysler parts and this part in particular. Right now I am literally deal in the water
Scott Mathey
gas line fittings
I too had the same problem at one point in dealing with gas line fittings for outboards. I went to a brass products and fabrication and fittings dealer. They have aftermarket gas fittings also had gas line hose that just presses on to the fittngs designed not to use hose clamps. I liked them so much I replaced all the gaslines and fittings. Good luck, hope this helps.
C
Cecil
BoatUS, WEST ?
I`ve got an `81, found parts(gas fitting) at a local marina. If you can`t locate one, let me know I`ll send you one. Interested in a motor for parts?`81 long shaft, broken piston land ?make offer, you pay freight or pu in NC. Contact me at cecil_tiller@yahoo.com
