Jim WIllis
I've had a problem with water leaking out of the fresh water tank. Worse case scenario was a leak in the tank. I found a leak in the pressure pump to th facets and shower - it was the rubber that seemed rotted.Still the leak. Finally, Looking under the floorboards, I think I found the problem: An additional leak in the foot operated secondary faucet in the Shower/Head area.Will block off and see if leak is fixed. But where do I get a replacement pedal pump?Thank God!ALW
