Chicago Area Maintenance on My Yanmar 2QM15
Dick from Chicago
This is an urgent request. We need a reference for someone in the Chicago area to help us with a problem on our Yanmar 2QM15. We are unable to get forward drive however we are able to move in reverse. After disconnecting the cockpit linkage and contolling the transmission directly, the problem persist. The propoller will rotate in both forward and reverse directions but under forward load, the shaft will almost come to a stop.
Dec 2, 1999
15,184
Sounds like a transmission problem.
Dick: I sounds like you have a transmission problem. You may want to check with the Yanmar Distributor in your area about a rebuilt tranmission.
Ralph Johnstone
Steve is Right ...............
......... about looking up ONLY your local Yanmar dealer, probably in your telephone directory. I don't know about the Chicago area, but up here, we have some real characters who will destroy your engine and charge you a fortune in the process. Good Luck, s/v Island Hunter
Steve O.
TMI
Torresen Marine, Inc in Muskegon, MI 231-759-8596 www.torresen.com
Brian
try the Yanmar dealer....
Attached is the link for the group that teaches yanmar maintainence classes in the Chicago area. They could be a good source to go to, as well as know who might be the best people to contact nearest you.
