cherub78
Nov 4, 2012
21
hunter 27 bathurst
Its strange that the oil I drained was black and the new oil was grey after 5 minutes of checking it.I put in 30 grade oil. Thanks
'twil always be thus.
It's a diesel.
Don't worry. It's the way it is.
It's NOT a gasoline engine.
Dec 2, 1999
15,184
Yup. The older the engine the more likely the oil will be dirty after few minutes. The newer models stay cleaner longer.
Mar 6, 2012
357
Hunter H33 (limited edition cabin top) Bayou Chico
yup, if you rub it tween ur fingers and it doesnt feel like there's a little grit in it, then ur fine. thats how i gauge when to change mine.
May 24, 2004
7,174
CC 30 South Florida
As long as the gray color does not mean emulsified water and oil it's no cause to worry. If it is the original engine it is 30+ years old and 30 weight oil would likely be a bit thin. I would rather use 15W40 which when hot will be a little heavier and will improve compression.
