Has anyone replaced their Cheek Blocks on their H31? They are the blocks near the transom that the jib sheets run thru to the winches. I was out yesterday in pretty good wind with the Genoa reefed and sheeted in pretty tight. The cheek block was screeching as we went over the waves. Interestingly it was only the Port Block the Starboard Block was fine. I figure its time to replace both. Is it a standard size that just needs to be measured or are they a special order item? I was thinking of replacing them with Garhauer.
