Here's why
Oreana123,
There are several reasons for checking the mast rake. Most importantly, the boat sails differently at different rake angles. My 26D had a 5 degree stern rake from the factory. I talked to another mac owner who had corrected his rake and then changed mine to straight up (0 rake). This corrected some of my rounding up problem and made it easier to balance the sails. I did this by drilling a new hole in the mast about 6" above the first holes and reconnected the forestay saddle there. This was easy and can easily be undone if I ever change my mind. Then I lengthed the backstay and tightened it up. On my mac, I also had to lengthen the sidestays. It was pretty easy.
What else? For one, my mac looked so funny in the marina with all those other boats. It had an inferiority complex because its mast was cocked off to the side. Second, doing this raised the end of the boom, so there was less chance of getting hit. But mainly, it sailed better.
How to check? Here is how I checked mine. First, I knew that my hull stripe (the one near the water)(or you could use the water scum line if your boat has been in the water for a while) as a measurement of level while in the water (level line). Then, back off the beam a ways, maybe 20 or 30 feet and use a right angle to check the mast rake against the level line. You could use a protractor or just a rectangular sheet of paper. It will be obvious what the rake is. One other thing, some boats are supposed to have a mast rake. I don't know what the factory says about the V22. First, I would check the rake to see what it was, then check out the specks.
An easier way to get a rough check, dock the boat at a marina where you can line up with several other sailboat, back off so you can compare all of the masts in line, and you can get a pretty good idea what is going on. With a protractor, you can even measure rake this way.
Enjoy your V22. I loved mine, especially when she sang to me.
