G
George Kornreich
I'd like to know if anyone has found a good way to check the BOTTOM of the fuel tank for water and debris. Checking the Racor drain should always be done but it doesn't sample what's on the tank bottom. Is there some sort of dip-tube that can be put in through the sender-gauge opening that can drqw a sample from the bottow? Any other ideas? Thanks
