check batteries for sure
Hi Don; batteries are one of the most neglected items on a boat........out of sight, out of mind. Check them regularly and clean the connections as well. They may appear to be clean, but enough corrosion to hamper proper charge and discharge cycles isn't always visible. I have 85 lb. batteries in my Cat320 that I leave on my boat all winter. I charge them every 4 - 6 weeks, depending on temperatures. Use a hydrometer to see if the cells are strong. A voltmeter will not show you if the battery will work under a load.....ie. start your engine. Some people like the Surette brand. Very expensive, but you might get 10 years out of them. You can either replace a cheap one every few years, or go with the better ones.....choices, choices. Must be springtime in beautiful B.C. We still have plenty of cold here...-14 C tonight.Cheers,Ron
