Float switch is mounted to low
If your bilge pump is cycling, your float switch is mounted to low in the bilge in relation to the suction on the pump. You can either lower the suction point or raise the float switch. A few inches either way will make a lot of difference.Several of the previous replies hit on good reasons for not using check valves in bilge pump lines. Check valves (especially small plastic ones) are famous for clogging up and/or freezing up, restricting or preventing the flow of bilge water.Remember the main reason for having a bilge pump is to prevent the boat from sinking in an emergency. I agree with Peggy about keeping the bilge clean, it's a safety issue. But it doesn't take much to plug up a small check valve and it always seems to happen at a bad time. If you hit a log and put a hole in the hull, lots of things will start floating around in the bilge, and you wouldn't have time to clean out a check valve. On the other hand if the boat is at the dock and you are not there, a plugged check valve will result in the pump running constantly and draining the battery or burning up the pump.I have two pumps on my boat. One manual pump and one automatic/electric pump. The suction on the manual pump goes all the way to the bottom of the sump in the bilge. A few strokes with the manual pump and there is less than an inch of water remaining at the bottom of the sump. The electric pump only comes on when I use the shower. I wish I had a separate sump and pump for the shower, but I don't.Hope that helps.John
