H
HARVEY
THERE IS NO ROOM FOR A VENTED LOOP BETWEEN THE HEAD AND THE OVERBOARD DISCHARGE, WHICH IS LOCATED IN THE PORT SIDE LAZERETTE FORWARD OF THE HOLDING TANK, THEREFORE SEAWATER BACKS UP INTO THE BOWL WHEN SAILING OR NOT. CAN A 1 1/2 " CHECK VALVE BE USED IN THE LINE OR WOULD THIS PRESENT A CLOGGING PROMLEM ? WE USE THE BIODEGRADABLE PAPER. THE SIZE OF THE FLAPPER IN THE CHECK VALVES I HAVE LOOKED AT APPEARS TO BE ABOUT 1"-1 1/4'
