cheapo refrigeration
N
Nelly
I have a decent sized ice box, aproximately 24"W x 30"L x 30"D. My question is would it be possible to buy a cheapo small bar refrigerator and install the guts in the icebox for use when connected to shore power? Has anyone tried this?
Dec 2, 1999
15,184
It has been done!
Nelly: It has been done and many owners are quite happy with the results. Just remember there is no practical way to use this away from 120VAC shore power!
Barry
Do It!
Check the link below to a picture article I posted here a few years ago. Total refigeration costs were about fifty bucks but I added an expensive marine inverter and extra batteries for offshore use. I've done others with inverters from Harbor Frieght that cost under $100. Paid for itself several times just in ice savings plus ...... I can make jello shots in any anchorage! (if the link doesn't work, search the archives using h34 and refigeration. Have fun!
Ron
Me Too Also!
I also use the guts from a small 120V refrigerator with no complaints. In fact, the first time I used it I awoke in the morning to find everything frozen solid. No syrup on the hotcakes that morning. Mine had R-12 in it so I replaced it with R-414B after installation. Much colder and a WHOLE lot cheaper, too! Most likey you'll want to get one that uses R-134 so you can buy more refrigerant after you resoldier the lines. I'm an AC Tech so that's why I went for the more exotic refrigerant. Ron
E
Ed Schenck
Dorm frig.
We have a 110V dorm frig where the oven once lived. It draws about 9 amps(DC) when running, runs about 20 minutes an hour. Not sure if surrounding it with insulation would make a difference. Whadda ya' think Ron? A fellow came on a new Hunter at the show and saw the new front opening Nova Kool refrig. He went on and on about the inefficiency of a front opener, all the cold dumping out, etc. But these new Nova Kools are rated at 20 watt-hours. This is less than 2 amp-hours if I understand this. Seems efficient so long as you are not constantly opening it. A 3.5 cu. ft. Nova Cool is $700.
Barry
Soldier the line?
I removed the guts from the fridge without breaking the lines and cut a hole in the ice box big enough for the evaporator to pas through. Still using the original R12. Ain't broke, why fix it? I believe this installation is more efficient that the original fridge due to top opening and better insulation (it runs less)
Bob Camarena
I guess I'll have to do it this year
I've read and re-read Barry's article for a couple of years now while my unused dorm refrigerator sits in the garage. I'm going to definitely do it this year. Barry, I was wondering what kind of power consumption you experienced with the "cheapo" inverters. I have an 800w/7a (1600w surge) Coleman inverter that I got on sale at Kragen. Bob
