Hey thats MY fuel system ....
... and was the configuration as of 2001/2002Your illustration omits the 'notes' that I originally listed:Uses only double flared tubes on delivery system. Coppper lines being replaced with double flared Stainless tube. (Reason: 1. copper is reactive with #2 Fuel Oil; 2. copper vs. compression/flared fitting 'relax' over time allowing air leakage on suction feed system) Changed location of priming pump to 'at the tank' to enhance air bleeding of the system.Recirculation system is ON anytime engine is ON. The recirc. filter housing WAS "Ametek type" glass filled polypropylene ..... (glass filled polypro 'swells' over time vs. diesel fuel) All system O-rings/gaskets changed to EPDMSuction dip-tube of recirc system located *at* the very bottom of the tankSystem will maintain in-the-tank resident (background) particle levels to less than 0,45uM (via nephalometry correlation to µM). Free water is removed from drain tap of recirculation housing.All filter performance monitored via gages with reference to engine at WOT (max. rpm) Since 2002 No need for redundant/paralllel 4 valve block and bypass Racor system. If you have good recirculation, the challenge to the Racors will abe minimum. If any problem develops in the system the 3 gallon day tank can be switched into the circuit .... has about 4 hours fuel for a 35-50 hP engine. Added a desiccant filled water vapor trap on the vent line to stop water vapor ingress .... desiccant is contained in polycarbonate cyclinder. Uses activated alumina as dessicant with colored (saturation indicator) Silica Gel. @ about 2/3 the depth of dessicant to visualize the need to regenerate the desiccant. Desiccant Regeneration is via vacuum (cleaner) for 1+ hour to remove oil vapor, then 8 hrs. bake at 350degrees in kitchen oven. Changed out the recirculation filter housing (was polypropyne glass filled "Ametek type" ) to Carbon steel T-type with bottom drain tap (Shelco Filters)As regards the GoldenRod filters: Clear plastic bowls on boat fuel filters wont pass survey (ABYS specs.) if you plan to sell the boat in the near future. Not knocking the GoldenRod filters in any way but their configuration is 'proprietary' .... meaning you're stuck using only one manufacturer. The world's "industrial standard" for coarse filters is each 'element/carrtridge' at 10" length (or multiple of 10") X 2.5" or 2.75" OD .... then you can pick and choose from literally hundreds of manufacturers. The GoldenRod filter material is resinated cellulosic felt (the worlds 'single source' of this media is probably Ahlstom in Finland) ... OK for single pass filtration of fuel oil, is accurate retention but doesnt have much dirt-capacity. Without going into all the bloody details of filtration mechanisms, etc. .... for a recirculation filter you want a high capacity 'depth media' filter ... something like an OSMONICS "Hytrex" GX10-15 ...meltblown polypropylene fiber in a graded pore density matrix...... The most important thing to mention is not noted or listed .... All this was started with a **CLEAN** tank that was mechanially hand scrubbed and flushed. I do not put any 'crap' fuel into the tank. When buying fuel I usually fill a clean glassful first, hold it up to strong white light with the glassful bewtween my eyeball and the light .... and if there is ANY haze in the fuel, I stop and simply go somewhere else. I keep the MINIMUM amount of fuel in the tank (only carry a small bit of reserve/emergencies). I totally empty the tank for wintertime layup, or other long layups, etc. I use dont use biocides, etc. BTW Ive been very deeply involved in 'filtration engineering" for the past 35+ years. Hope this helps. regardsRichH "Aquila" Ty37 #423
