		Phil
THIS IS NOT A CURE... but it did relieve about 95% of a head odor problem on my boat.As Peggy has stated in her information on what causes head odor, the holding tank in my boat was not getting sufficient ventilation.In order to improve that, I installed an aquarium air pump to force air into the tank.  The process took less than a day and only required getting access to the holding tank vent line at the through hull.  On the P42, this is located inside the forward cabinet.I cut a small slit in the vent line nearest the through hull and fed the small vinyl air line down the vent hose and into the tank.  The slit was then sealed with silicone seal.The vent hose connection at the tank is exposed under the seating.  This was disconnected to make it easier to work the tubing through.  The tubing should extend about 4 inches beyond the end of the vent hose.. in other words, just inside the tank.The air pump sits in the cabinet wrapped in a bit of foam and runs continuously.  Power is accessible from an outlet just below the cabinets.This has now been running for 2 months and I have no head odor problems in the boat at all.It would be best to do this with an empty holding tank... for obvious reasons... but mine wasn't at the time.  It took nearly a week before the stink settled down outside the boat as the tank was obviously working overtime on it's contents.  But now all is fine.Hope this can help someone else.
