Cheap Cabin Lights.
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
I have been using self charging LED yard spot lights on my boat for over a year now with great results. The lights are $10 from Wal-Mart for use in your yard as spot lights. I mounted 2 pieces of 3/4 inch pvc about 6 inches long to bow stachions and slip the lights in these pipes to charge during the day. In the cabin I have mounted the same type of holders and we put the lamps in them at night. They are very bright and great for reading or whatever. This is way cheaper than batteries, LED bulbs and all the other gear for lights. For $20 it lights both cabins in the boat.
Ray
Jul 1, 2010
990
Catalina 350 Port Huron
Cool. I'm liking these led strip lights on my boat:
http://www.amazon.com/LEDwholesaler...id=1369935935&sr=8-7&keywords=led+strip+light
They can be cut to length. I put a strip under the gunwale ledge on each side of the cabin. I'm also using this dimmer (one for each side):
http://www.amazon.com/LEDwholesaler...936160&sr=1-1&keywords=led+strip+light+dimmer
The complete light strip uses 22 watts. On my boat, the shorter strip mounted on the starboard side uses around 6 watts, the longer strip on the port side uses around 10 watts (on high). Make sure you get the "warm white" strips.
May 30, 2013
8
McGreagor Venture, Hobie 21,16 Trailer
Hobbyking has 1m strips of waterproof or regular led that are wired up to use 12v and consume only .4 ah or 400 mah they are quite bright and having just thought about them i think i will use them in my venture 21 the strips are only about $5 a peice and can be customized to just about any length you need
