Chattering AC relay
Bogart
Mar 13, 2018
34
Hunter 45CC Queensland
I have a 2007 45cc, imported direct to Australia from new and therefore set up with a 230V AC system. Recently the relay(s) behind the AC circuit board have started chattering when I turn on the inverter (which is a Magnasine MS2712E) and the voltage which is delivered by the inverter has dropped to about 125V (measured at the power points). I have engaged a tradesperson to come and check the relays, but note that my owner's manual does not have a wiring diagram for the AC system. Is anyone able to do so? I also note that some owners have gotten rid of their relays and used others switches. Has anyone with a 230V system done this?
Hope you are all well in these difficult times.
Cheers
Beneteau 323 Annapolis MD
Cheers
Not familiar with down under, but does 50 or 60 cycles come into play?
