Chattering ac distrib relays
Jul 14, 2010
1
Hunter 45CC Maryland
My ac panel on our hunter 45cc 2006 has been intermittently chattering for a couple years. Then it finally started chattering non stop. I replaced the potter and brumfeld relay that was doing the chatter but it turns out it was one of the 4 'latching' relays at the top of the panel-see
http://www.kgtechnologies.net/PDF/KG-K850_Latching_Relay.pdf
They only sell wholesale so buy at www.newark.com $6 each.
Problem is they're a real pain to unsolder and resolder to the silly homemade circuit boards hunter used that year. Btw-local repair guy said this is common on these boats.
Good luck!
Jun 14, 2007
180
Hunter 45cc Florida
My 06 45cc circuit panel caught fire due to one of these relays. Luckily I was aboard. I would recommend you check out my rewiring of panel to delete these devices. Rewiring using a seablue on off selector switch. It can be found in the owners mods.
