Chartplotter to VHF hookup
56
Hunter 376 Kent Island, MD
Please Help!! What is the pathway for wires to be run from the cockpit helm station to the electric panel & VHF at the Nav station? Trying to place new chartplotter & RAM3 mic. Much Thanx. murph243@msn.com
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Looking
You will need to try and find other wires going tto the helm and do some tracing of wires going and coming is the only advice.
I have owned 2 Hunters and have run different wires for different things on both boats by taking things apart where ever I see screws leading to compartments dealing with what you want to add.
Nick
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
On my 410 there is a conduit that runs along the port side from the nav station to the rear port locker. Check behind your nav station to see if there is a conduit. From the locker I need to go down under the pedestal and come up where the existing wires come up. although I have drilled new holes up into the pedestal as there was not sufficient room for more wires.
If you do find a conduit hopefully there will be room for more wires. You will need an electrical snake to get through it. If you can't find a pathway you might be able to go under the floor/rear berth and find a path. Good luck.
