chartplotter no magnetic door
353
Hunter 37 FL
Does anyone know of a chartplotter on the market that does NOT have a magnetic door? Apparently Garmin's current models have a magnetic door that interferes with magnetic compass.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
take a look at the 714s and see if you like it they are a little pricey but they dont have a door just a cover that snaps on....
regards
woody
correction that is the 720 and 740 models
Buy the model you like and remove the stupid magnet. That's an option. Cost: almost nothing.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
There are a lot more to the chartplotters than the door that might affect your compass. Our Standard Horizon CP300 does not have a magnet in the door. Chuck
Apr 8, 2010
2,238
Comparisons.....
Check out Raymarine and Furuno.
The later is preferred overwhelmingly by professional mariners.
L
(If compared to sailboat builders, Garmin is to marine electronics now as Reinell was to sail boats in the 70's.)
Hunter 37 C sloop Punta Gorda FL
We're done with Garmin. Lies like"we never heard that before", " You need to ground your compass" and "the milliamps flowing thru the unit will affect your compass more than the magnet" have convinced me that this is not a company to be giving my business to.
I'm not going to make the effort to check, but I am told that doing so voids the warrantee on brand new units.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Bill
My Raymarine C-80 does not use a magnet for the chip door,did you go to WM and check them out yet.
Nick
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
All marine equipment should have a quoted "Compass Safe Distance". If your chosen unit does not show this in the manual (on line?) then ask Garmin for it.
Compass Safe Distance is the distance away from the object at which a compass will not deviate by more than 5.4°. i.e. within the range of being compensated for - and not too bad if not!
Garmin will, of course, be very aware of the potential problem and it seems likely that, when the door is closed, there will be very little radiated magnetic field.
If Garmin have overlooked this issue then they will have some head scratching to do!
Have fun​
Dec 2, 2003
1,637
Lost the button to delete duplicates??
No longer able to edit text layout - sorry everyone - maybe not me after all?
Apr 8, 2010
2,238
Nowhere NEAR your compass...
Garmin buries the info deep in their PDF install manual for these devices, but the distance is given as 37" or 39", IIRC.
L
Ross
Jun 15, 2004
14,693
Re: Nowhere NEAR your compass...
I was just checkin with a small pocket compass and a cabinet door magnetic latch. A small piece of steel bridging the magnet significantly reduces the magnetic interferrence. Try it with the case closed and then with the case open to see if there is a substantial change.
