Chartplotter Baffled
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
Our chartplotter, Raymarine C70, has 9 different trip logs.
Log Trip
Log
Trip
Ground Log / Trip 1
Ground Log
Ground Trip 1
Ground Trip 2
Ground Trip 3
Ground Trip 4
What’s the difference? How do you use them? I can’t figure out how to zero anything? Without this I can’t get very far. Does the Log run since power was connected? What if it’s disconnected? We don’t have a paddle wheel, only GPS, does this mean you can only use Ground Log and not Trip or is it Log that won’t work? As you can see this is quite the snake pit of features.:) Any insight from any make chartplotter might help clue me in to what is maybe quite obvious.
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
Found the reset
Thanks for the leads. I found the resets under the menu button, then system setup
