Charles marine charger
Jun 16, 2011
173
Catalina 350 Rock hall
we just bought a boat with a Charles marine charger. Is this a quality unit?
It is a 5000 model 30 amp. This is our first boat with all these systems a/p, fridge etc. I am not sure what to expect, what kind of issues or concerns should I have running fridge while away from boat? The boat is a Catalina 35 2005.
You mean a Catalina 350? Does the charger have settings for different types of batteries (i.e., wet cell, gel, AGM)?
Mar 20, 2012
3,983
C- Chargers..... they are a good units... there may be better ones, and there are definitely much worse that are being used...
I would be happy with it....
May 10, 2008
392
Catalina 355 Boston
Most larger Catalinas have been shipping with the Charles since the C350 was introduced up until about 3 years ago, when the factory switched to the Pronautic for the 5 series boats. My 355 came with the Charles. It is an okay charger, but wouldn't be my choice if replacing (I would go with a Pronautic, Sterling or Newmar).
The Charles has user selectable battery type settings, however they are on the back of the unit and set via dip switches. It also does not provide for equalization. It is also one of the most expensive (overpriced) chargers if one were to buy retail.
Bottom line, it is a serviceable charger and certainly not worth ripping out unless or until it fails.
As a new owner of a 350, are you a member of the 350 User forum? Very helpful site for all things regarding your boat. Congratulations on your boat!
Jun 16, 2011
173
Thanks for all the replies I am a member of the c350 site
It seems sbo casts a broader net!!
We are closing on her today, here goes nothin!!
Feb 6, 1998
11,701
What I like:
Made in the USA
UL Marine Tested
5 Year Warranty
4 Hour "Egg-Timer" Absorption (better than most dumb so called smart chargers)
What I Dislike:
Only three voltage choices (dip switch)
Ambient temp sensing (at the charger)
No on battery temp sensor
Absorption voltage not adjustable to fit YOUR batteries
Float voltage not adjustable to fit YOUR batteries
Absorption time not adjustable
Lack reabsorb cycle to prevent electrolyte stratification
Lacks an equalization cycle
Not suitable for charging many AGM batteries in a healthy manner
Not suitable for charging many flooded batteries in a healthy manner
Cooling fan not variable speed and simply turns on at 50% of output
Temp compensation (ambient "at-the-charger" based) is not adjustable
Not "world voltage" ready
I have really grown to dislike over-priced chargers that call themselves smart when they are so far from smart it is laughable. There are some pretty serious deficiencies in this product and unless your batteries fall into one of three available voltage settings:
Flooded 14.5V Absorb > 13.6V Float
GEL 14.2V Absorb > 13.6V Float
AGM 14.2V Absorb > 13.4V Float
Then it is not the charger you should be using. Dip switch chargers, in this day and age, are a joke and we certainly should not be paying a premium for them so they can mistreat our batteries. For example:
*What AGM Battery Makers Want to See:
Lifeline AGM's = 14.4V & 13.4V
Odyssey TPPL AGM's = 14.7V & 13.6V
Firefly AGM =14.4V & 13.2V
Mastervolt AGM = 14.4V & 13.2V
Full River AGM = 14.7V & 13.7V
Rolls AGM = 14.7V & 13.7V
East Penn/Deka = 14.6V & 13.6V
US Battery AGM = 14.4V & 13.4V
Trojan AGM = 14.4V & 13.5V
Not one charge profile that matches or will be optimally healthy for AGM batteries in deep cycling use.
* Every one of these battery makers wants to see on-battery temp compensated charging.
How about the flooded setting for the very popular Trojan batteries?
Once again the Charles charger fails to give you a "dip-switch" profile that charges Trojan's properly or in an optimally healthy manner..
Any charger that does not offer physically on the battery temp sensing is simply not a "smart" charger.. Beware that many charges that claim "temp compensation" are doing this via ambient temperature at the charger, like the Charles SP-5000. If the charger is in a cool spot and the battery in an engine bay you will cook your batteries. This is simply not smart....
Sadly the term smart charger is bandied about these days like a ping pong ball. I think Deka / East Penn, one of the largest US battery manufacturers, cautions well on "smart" chargers.
Quote = Deka / East Penn
"Unfortunately, many chargers on the market claim to be gel/VRLA “friendly” or “OK for sealed batteries”, but are not. Some overcharge the batteries, while others may not fully charge the batteries. Some chargers claim to be “smart”. Some “smart” chargers do a good job, others do not. The best choice of charger often depends on the application.
Almost all applications require temperature sensing and voltage compensation. Beware, many chargers measure the ambient temperature which could be significantly different from the battery’s internal temperature."
The bottom line, if a charger claims to be "smart", and it does not have a temp probe that can be physically mounted to the battery bank, IT IS NOT A SMART CHARGER.
You already own this charger so use it until your batteries die then consider a better charger for the new bank. Any charger in this price range, that does not offer a "custom charge profile" to be created, and a on-battery temp sensor, is simply a rip-off.
Here's the bottom line when buying a charger:
Just say no to dip-switch chargers!!
Just for grins here is a competitors 30A charger that also has a 5 year warranty and comes standard with on-battery temp sensor. It sells for $150.00 LESS!!!
It has 13 different pre-set choices, as opposed to just three, including equalization, plus the ability to create a custom absorption>float charge profile to match your batteries exactly. The charger is PFC (power factor corrected) and extremely efficient, about 90% and the AC input is also fully automatically auto-ranging and it will tolerate low voltage or crappy dock power with ease as well as 50 or 60 Hz.
May 24, 2004
7,164
CC 30 South Florida
Quality construction with 20 year old technology. There are better performing choices in the market today but If your is working fine and you use wet cell batteries I would continue to use it until your needs dictated otherwise.
forbin
Nov 4, 2013
166
Tartan 3700 Seattle - Elliot Bay
I had a 2002 model which I just replaced which did *not* have the switch for different battery types (which is why I replaced it when I went with AGM's.) While it doesn't sound like you're planning to replace your batteries, make sure you check the exact model before assuming it supports multiple battery types if you intend to continue using your existing charger.
