David
I have a 2005 38 Hunter I bought new that I have had many problems with. It was a early production with red boot stripes and tan binimi. The factory wiring was incorrect and the dealer has already gone thru it. The batteries will not charge with the engine running but will with the shore power connected. The volt meter will only show 12.5 volts with the engine running and will slowly drop as items are turned on. The dealer says that I have to have the engine running at around 1500rpm to entergize the alternator to charge. This would then not be possible at dock or at anchor because the boat transmission shifts into gear. Shouldn't the alternator charge at 13.9 to 14.2 volts at an engine idle? Is the dealer correct?
