You would want to take a look in each cell for proper level. If needed, add distilled water not simply tap water. distilled water can be obtained from an auto parts store but I collect if from my house dehumidifier. If you leave the caps off you can see which cells are bubbling(even on a trickle charger) and if one is not bubbling during charge it could be a "dead cell" suspect. Other than that, they're perfectly fine as vented with the cap on and won't splash corrosive acid as much onto the top of the battery. Make sure the area in general is vented if the batt is secured inside the boat, I do a full charge at the end and beginning of the season with the battery already removed from the boat.
