More definitions
OK, I did get Nigel Calder's book "Boatowner's Mechanical and Electrical Manual" 3rd edition and I have been reading and studying. I have also tried to diagram my electrical system. I have read as many posts as I could regarding this subject (until the REALLY technical stuff gets too deep).
Good. It’s NOT really too technical, simply because there are only a few parts: the charging source (alternator or shorepower or solar or wind) and the batteries. All the rest is switching (and the wiring in between). Really.
I have tried to find out the difference between "isolator" and "combiner" but so far can't find any explanation - I will keep looking.
I have the second edition of Calder’s book and my book makes it pretty clear - did you use the index? Anyway: An isolator is a diode that as Don said takes a very important 0.7 V or more drop. They were originally used in the 70s and 80s to isolate batteries after charging was done without switching. They are stupid because of the voltage drop. 1 V is the difference between a full and dead battery!!!If you have one, remove it after you figure out how the system IS, and may not yet necessarily should be, wired.
A combiner is simply a voltage sensitive, battery paralleling (solenoid), a RELAY, that opens and closes under certain conditions. It closes (connects) when the charging voltage is over a preset limit, usually 13.1 to 13.4 V) and opens (stops) when the voltage goes to 12.8 V or less.
What I DO have on my boat (keep in mind that I am at least the 4th owner and previous owners did some really strange electrical modifications that I am still trying to correct) is a gray metal box that says West Marine Battery Combiner II, Model 134074 which is NOT hooked to anything. I have tried to find info about it by model name and number but can't so I don't know what it is supposed to do or how to wire it to my electrical system (the 3 connectors look way to small to attach the positive battery cables to).
I have the original 1998 WM Combiner Installation Instructions (which also used to be on their website), and the model # you quote is a 70 A two bank model, right on the manual. Email me and I’ll scan it in and send it to you. The small output wires work just fine, as you’ll see. Combiner wiring (#6) does NOT have to be as robust in size as battery (i.e., #4 to #2/0!!!) wires.
I also have an orangeish colored box with heat fins that has NO name, numbers or anything on it. That is what I assume is the "isolator" or "combiner" that is currently connected to the electrical system via the positive cables (one coming from the alternator by way of the ammeter and then 1 each going to the 2 positive battery terminals (my battery banks consist of 2 type 27 deep cycle batteries connected together for HOUSE bank and 1 type 27 starting battery for the START bank).
I am sure that the heat fins are a giveaway – it is an isolator.
PLEASE, everyone, stop using “isolator/combiner” as a phrase. It just doesn’t exist and is confusing things. It’s like saying “boat/airplane” – puleeze. For some bizarre reason West Marine is now calling the one they do sell (search on battery combiner on WM website) a "combiner/isolator," most likely using the "isolator" part of the phrase to mean when the relay opens the banks are isolated. Weird, because combiners are different animals than isolators. Must be a marketing gimmick. I can even consider the phrase "combiner/isolators," but not the two words reversed. Picky, picky picky...just an another damned engineer...
They sold the model you have, Gary, as a "Battery Combiner."
You say ”
connected to the electrical system” :If I can “refine” your description: from the alternator output, to the ammeter, to the isolator to each individual bank.” That sounds somewhat strange, because you don’t mention your 1-2-B switch at all. Does the alternator output then through the ammeter to the isolator go around the 1-2-B switch?
I am trying to find out things without bothering people but when I run into dead ends, I post questions. I also have limited funds so can't really go out and buy Balmar alternators and regulators and modify my pulleys and mounts.
This is no bother, I love this stuff, but the better you can describe things, the more we can help. In the course of the past year I’ve helped many skippers with their systems, two right on this ‘board, so keep ‘em comin’, that’s what we’re here for.
Gary, you have two challenges: 1) what you have, which ONLY you can trace, ‘cuz I ain’t there next to ya; 2) what you want to do, which will determine how easy or difficult it might be.
You may want to check these:
A good description of basic "how things work":
http://c34.org/bbs/index.php/topic,4949.0.html
The wiring diagram from my boat in this link, page 2, reply #23:
http://c34.org/bbs/index.php/topic,4623.15.html
I look forward to your email, I’m scanning it now for you.
Stu
