The front-back dimension is the biggest difference
between the "standard" and "highboy" size bowls on just about every toilet. There's only about an inch total difference in widths of the bowls, but depending upon the pump, the total difference in the width of full size vs. a compact toilet can vary from only an inch or so to several inches. What most people fail to take into account when they measure is that the discharge hole---and therefore the mounting bolts--in both size bowls is dead center in the bowl, which means you need additional space behind the bowl for half the difference in the length of the two bowls. If the one you have now is jammed up again the wall, the larger one isn't gonna fit unless you move the whole toilet forward. Even if that puts the front of it over the edge of any platform it sits on, that's not a big deal to overcome. Fill the existing bolt holes, put down a nice 3/4" teak or mahogany board that not only covers the old holes, but extends the platform far enough forward and mount the new toilet on top of it. Screw the board down, do NOT use epoxy or anything permanent....the next toilet's bolt hole pattern may not match your new toilet's either, in which case you solve that problem by replacing the board. So you don't want to put it down permanently. You can seal the edges with silicone sealant to keep moisture out.
