SERIES = ADD VOLTAGE - AH's STAYS THE SAME AS ONE BATTERY
PARALLEL = ADD AMPERE HOURS - VOLTAGE STAYS THE SAME AS ONE BATTERY
Two 6V 225Ah batteries wired in series is a 12V 225Ah battery bank
Four 6V 225Ah batteries wired in series pairs then the two series pairs get wired in parallel for a 12V 450Ah battery bank
Six 6V 225Ah batteries wired in series pairs then the three series pairs get wired in parallel for a 12V 675Ah battery bank
Think of it this way; It takes six 2V cells to make a 12V battery. So a 12V battery has six 2V cells inside it. A 6V battery has just three 2V cells. When you wire two 3 cell 6V batteries in series, - to
+ is series, you now have six 2V cells and a 12V battery.
For many reasons you will be best served to wire the bank as one large contiguous house bank with no 1/2/B switch in-between any batteries in the house bank. If you want a start or reserve bank as BANK 2 and house as BANK 1 that's a good use of a 1/2/B.
A 450Ah bank would get wired as shown. For 675Ah's you would simply add another series pair to the right or left and parallel them in. Take off points should remain at opposite corners of the bank:
