Cable replacement
I just helped a friend replace both cables on his O35, and, in his case, it was the shift cable that was binding. He had to grind off the tops of the bolts/screws that held the compass in place, then bought new ones. When he pulled the old cables, there are some definite quirks involved. The chain has to be loosened and moved forward out of the way, the entire assembly has to be pushed down below the steering shaft so everything will come up on the port side, the cable clamp has to be oriented so that the bolt faces outboard, and a line fastened to the power plant end of both cables if they happen to run through separate holes somewhere below. Anything dropped into the pedestal stays in the pedestal. There is a small hole in the bottom of the pedestal that allows the cables and the chain to exit, but nothing else. The advice of checking the levers while evrything is disassembled prior to pulling the old cables out is an excellent idea. In our case, the throttle cable was smooth as silk, but the shift cable was defunct. We replaced both anyway, with the best Telflex in the Defender catalogue (wish I had saved my post to another list). Anyway, it is definitely a two-person job, reassembly at the engine end is a one-man job, involving excellent small-motor muscle coordination and an extensive vocabulary, but the results are well worth it. FWIW,Bill Coxe, O40 Kukulcán, New London, CT
