Changing the fuel filter
russ downen
Can anyone out there tell me how to go about changing the fuel filter on the yanmar 1gm10?
Dec 25, 2000
6,062
Hi Russ, check the archive link below...
http://archives.sailboatowners.com/pviewarch.htm?fno=0
Oct 30, 2007
11
- - Lake Travis, Austin, TX
Link Broken?
Terry, Can you check the Link, as it does not work for me.
Dec 3, 2003
2,101
Russ, Then This May Help...
http://www.yanmarhelp.com/s_anode.htm then select the topic. Good Luck! :)
Dec 25, 2000
6,062
Hi larry/Russ, right after I posted the link...
I tested it and it worked fine. Sometime between when I tested it and when you tried it the system dropped the last third of the link address. The link connected you to an archive posting of articles that dealt with filter changing. Just type in changing fuel filter and lots of information will pop up. Terry
