Dennis
First step is to close you sea cock, for the raw water intake, if not you'll flood your boat. Next you'll need to loosen to belt to the pump, then remove pump from motor. Take the pump off hoses, some water will come out but will stop if sea cock is closed properly. Remove (be careful of the brass screws, you may use penetrating oil if too tight) backing plate, scrape gasket off, the pull impeller, paying attention to direction of blades, you'll want the new blades going the same direction. Replace gasket, backing plate. This is a good time to check your hose, you may want to replace it and/or the clamps as well as the belt. Once reinstalled, check pump with engine running, SEA COCK OPEN, with flash light, looking for drips. If there are drips you may need to replace or rebuild the pump, which is normal for 300-500 hour of use, you may want to do this inspection before you remove the pump, but always check after. Make sure belt is tight, not too tight and your good to go.
