Yebbut why not use a scavenger pump to remove most of the used oil before twisting off the filter?Sent from
TypeApp
Sent: Sun Dec 04 20:17:00 GMT+00:00 2016
To: "
AlbinVega@yahoogroups.com"
Subject: Re: [AlbinVega] Changing oil filter without changing oil
 Im not sure how the filter is mounted on the md7a, but on some cars that I have had in the past that had horizontal filters that would dump oil out as I unscrewed them, I would punch a hole in them to let most of the oil drain out of the filter before
 I removed it from the engine. I have  also made diverters out of aluminum foil to direct the draining oil to a catch pan.
Having lots of absorbent material on hand also helps. Tg
On Dec 4, 2016, at 3:26 AM, prachtschip@... [AlbinVega]
AlbinVega@yahoogroups.com wrote:
