Mounting Holes
Unless you are replacing the exact same make and model of toilet, rest assured – the mounting holes between the old one and new one WILL NOT line up. Even with the same make and model, if too many years have gone by between the older one and the newer one, they still may not line up.At home, you can have your plumber rip out an old, round front American Standard toilet and replace it with a brand-new, elongated Kohler toilet, and the mounting and the plumbing will align perfectly. Not so in the marine industry. Why not, you ask?All marine toilets, other than portable toilets (Porta-Potties) and drop-down RV-type toilets, use pumps of one kind or another to operate: piston pumps, diaphragm pumps, centrifugal pumps, rubber impeller pumps, progressive cavity pumps, rotary piston pumps, gear pumps, vacuum pumps and probably some other types of pump that don’t readily come to mind. Then, to go one step farther, the pumps will vary from manufacturer to manufacturer and model to model as to their size and their capacity. With the wide variety of pumps available to use on a given marine toilet, the method of mounting it and the location of the mounting tabs for the toilet will vary because the manufacturer must locate them where they will provide adequate support for the mechanism and at the same time, not interfere with the actual operation of the unit. The same applies to the locations for connecting the input and discharge hoses. They must be where the input and output ports are on the pump being used. About the only standard for marine toilets is hose size. Most marine toilets use ¾” I.D. hose for the input and 1½” I.D. hose for the discharge. A few manufacturers, on some of their products, use 1” I.D. hose for the discharge, but the most common hose size for the discharge is 1½” I.D.
