Bob
I have a Catalina 30 ('88 model) with the Universal M-18 and the Hurth model HBW-50 transmission. I was planning on changing out the .29 quarts of fluid, but it looks like it could be tough without accessing the bottom drain plug. I will assume then that using a plastic tube for removal as with the engine oil is the way to go.Since this is a first time for me, can anyone provide any information from their experiences as to the best procedure. Do you run it hot before fluid drain since its high viscosity? The tranny seems to be on a slight angle as well.ThanksBob'88 Catalina 30 Mark II
