We just Changed the Jib Sheet
Rapp: We changed just the Jib halyard to rope on our C-22. The reason for this is that now we can bring the shackle all the way up to the bow pulpit when the sail is being hanked on. Being able to do this made my wife happy. Keep in mind that rope, or line, is now much stronger than it was when our C-22s were made. There are a few things that I do want to tell you. I did change the pulleys at the masthead. I actually made my own, because I have the tooling to do this and it only took a few minutes to turn the pulleys. Also, I put a thinner plate between the pulleys, that I also made. There is a plate that keeps the lines from getting crossed, if I remember correctly. I just checked a scrap of the line that I used and it is 5/16 inches in diameter. I did purchase it from West Marine, but I must mention that the first line that I ordered from their catalog was too stiff, and I had to return it. (I couldn't coil it up into the nice little coils at the bottom of the mast). The line that I have now is OK. If there's a West Marine store near you, and they are building them like McDonalds, you can make sure that you get the right line. You want line that doesn't stretch, but still can be coiled up near the cleat on the mast.I also must tell you that we had to add a winch onto the mast when we converted to line from the SS wire halyard. The line just won't stay as tight as the SS wire unless you can tension it with a winch. Actually we needed the winch anyway, but converting to line forced us to get it so that we could properly tension the luffs of our sails. I just remembered one more thing on this issue. We also changed to line from the SS wire halyard because our big jib, a Drifter, had such a long luff that wire would make it all the way to the cleat on the mast and then still have about 3 to 5 feet extra. We would have to wrap this around the downhaul cleat and then back to the jib halyard cleat. This wasn't great, but the all line jib halyard solved this problem.My main halyard is still wire rope. I'm not sure why, unless it is because it has less drag than a line halyard, and it runs along the front of the mast, when the jibs line runs along the rear of the mast. Also, it doesn't stretch much, and hasn't been a problem. I also used line with red and green tracers for the jib and main halyards, respectively. I hope this info. helps you. AldoThis is a followup to my previous post regarding changing from wire to rope genoa halyard. I have a 1982 C-22. To change to 5/16" rope, will I have to change the masthead sheave?
