Ralph Johnstone
Gordon,I have been to hell and back when it comes to changing the coolant on my 1998 Yanmar 2GM20F.The engine is attached to a hot water heater (at a lineal distance of 8 feet) and I take meticulous care to blow out all of the old coolant out of the supply and return hoses to the heat exchanger when draining the coolant.Next comes the 50-50 mix of distilled water and antifreeze ........... and the air turns purple with cursing. Firstly I cannot get the full amount of coolant back in because of air pockets. Next, when I start the engine and idle it, I can feel that the hot coolant is not circulating and eventually I get a hight temperature alarm. Shut down the engine. Some cursing and swearing. I remove the rad cap on the coolant reservoir and it is down slightly. Add a little more coolant until it overflows. Squeeze and knead every hose I can find, burp a few bubbles and add a few more drops of coolant. Start the engine ...... high temp. alarm sounds along with more cursing and swearing. Repeat the process ......... lots more cursing and swearing ........ and so it goes for at least a dozen tries before all of the air is gone. Once the air is gone, the engine temp. does not vary five degrees at any load. Perfect cooling control.I have added the coolant quickly, I have added the coolant slowly dropwise over a period of 15 minutes ........... no improvement. I have even left the hot water tank heater hoses full but no improvement.I need your help badly as I change the coolant religiously every winter and have been kicked out of three marinas so far and suspect vigilantes in this one. Things look poorly.Regards,s/v Island Hunter
